Журнал ядра
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.144 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r29233-443ec4032a) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Fri Jul 24 07:21:50 2026
[ 0.000000] Machine model: Routerich AX3000 v1
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004302ffff (192 KiB) nomap non-reusable secmon@43000000
[ 0.000000] OF: reserved mem: 0x0000000047c80000..0x0000000047d7ffff (1024 KiB) nomap non-reusable wmcpu-reserved@47c80000
[ 0.000000] OF: reserved mem: 0x0000000047d80000..0x0000000047dbffff (256 KiB) nomap non-reusable wo-emi@47d80000
[ 0.000000] OF: reserved mem: 0x0000000047dc0000..0x0000000047ffffff (2304 KiB) nomap non-reusable wo-data@47dc0000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x0000000047c7ffff]
[ 0.000000] node 0: [mem 0x0000000047c80000-0x0000000047ffffff]
[ 0.000000] node 0: [mem 0x0000000048000000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 18 pages/cpu s35112 r8192 d30424 u73728
[ 0.000000] pcpu-alloc: s35112 r8192 d30424 u73728 alloc=184096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line:
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 0MB
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x000000005f540000-0x000000005f5c0000] (0MB)
[ 0.000000] Memory: 496968K/524288K available (9088K kernel code, 1002K rwdata, 1680K rodata, 448K init, 305K bss, 27320K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: 0xffffffc080010080
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000084] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000093] pid_max: default: 32768 minimum: 301
[ 0.003044] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.003054] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.005293] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.005849] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[ 0.006000] rcu: Hierarchical SRCU implementation.
[ 0.006003] rcu: Max phase no-delay instances is 1000.
[ 0.006431] smp: Bringing up secondary CPUs …
[ 0.006811] Detected VIPT I-cache on CPU1
[ 0.006858] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.006890] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.006966] smp: Brought up 1 node, 2 CPUs
[ 0.006972] SMP: Total of 2 processors activated.
[ 0.006976] CPU features: detected: 32-bit EL0 Support
[ 0.006979] CPU features: detected: CRC32 instructions
[ 0.007011] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.007014] CPU: All CPU(s) started at EL2
[ 0.007016] alternatives: applying system-wide alternatives
[ 0.010983] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.010999] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.012316] pinctrl core: initialized pinctrl subsystem
[ 0.013641] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.013964] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.013990] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.014011] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.014422] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.014426] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.014429] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.014431] thermal_sys: Registered thermal governor ‘user_space’
[ 0.014471] ASID allocator initialised with 65536 entries
[ 0.015479] pstore: Using crash dump compression: deflate
[ 0.015485] pstore: Registered ramoops as persistent store backend
[ 0.015487] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.017056] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[ 0.023135] Modules: 29600 pages in range for non-PLT usage
[ 0.023144] Modules: 521120 pages in range for PLT usage
[ 0.024257] cryptd: max_cpu_qlen set to 1000
[ 0.025377] SCSI subsystem initialized
[ 0.025570] libata version 3.00 loaded.
[ 0.027351] clocksource: Switched to clocksource arch_sys_counter
[ 0.029642] NET: Registered PF_INET protocol family
[ 0.029757] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.031285] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.031305] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.031315] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.031346] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.031449] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.031681] MPTCP token hash table entries: 512 (order: 2, 12288 bytes, linear)
[ 0.031794] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.031810] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.032020] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.032054] PCI: CLS 0 bytes, default 64
[ 0.033555] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.038471] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.038478] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.095674] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.097724] gpio-export gpio-export: 1 gpio(s) exported
[ 0.108428] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.112258] printk: console [ttyS0] disabled
[ 0.132660] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 72, base_baud = 2500000) is a ST16650V2
[ 0.132704] printk: console [ttyS0] enabled
[ 0.895100] loop: module loaded
[ 0.901538] spi-nand spi0.0: calibration result: 0x3
[ 0.906613] spi-nand spi0.0: Fudan Micro SPI NAND was found.
[ 0.912306] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.921151] Signature found at block 1023 [0x07fe0000]
[ 0.926292] NMBM management region starts at block 960 [0x07800000]
[ 0.934528] First info table with writecount 0 found in block 960
[ 0.946249] Second info table with writecount 0 found in block 963
[ 0.952435] NMBM has been successfully attached
[ 0.957288] 6 fixed-partitions partitions found on MTD device spi0.0
[ 0.963655] Creating 6 MTD partitions on “spi0.0”:
[ 0.968441] 0x000000000000-0x000008000000 : “spi0.0”
[ 0.973393] mtd: partition “spi0.0” extends beyond the end of device “spi0.0” – size truncated to 0x7800000
[ 1.055762] 0x000000000000-0x000000100000 : “BL2”
[ 1.060946] 0x000000100000-0x000000180000 : “u-boot-env”
[ 1.066690] 0x000000180000-0x000000380000 : “Factory”
[ 1.072492] 0x000000380000-0x000000580000 : “FIP”
[ 1.077672] 0x000000580000-0x000007580000 : “ubi”
[ 1.236465] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc081700000, irq 75
[ 1.246403] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc081700000, irq 75
[ 1.256191] i2c_dev: i2c /dev entries driver
[ 1.262402] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.271673] NET: Registered PF_INET6 protocol family
[ 1.277987] Segment Routing with IPv6
[ 1.281686] In-situ OAM (IOAM) with IPv6
[ 1.285644] NET: Registered PF_PACKET protocol family
[ 1.290770] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.304412] 8021q: 802.1Q VLAN Support v1.8
[ 1.336122] phy phy-soc:usb-phy@11e10000.1: type_sw - reg 0x218, index 0
[ 1.407747] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 1.416645] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1.427839] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=79)
[ 1.450201] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=80)
[ 1.472261] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=81)
[ 1.483872] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[ 1.490637] DSA: tree 0 setup
[ 1.494524] UBI: auto-attach mtd5
[ 1.497897] ubi0: default fastmap pool size: 40
[ 1.502418] ubi0: default fastmap WL pool size: 20
[ 1.507196] ubi0: attaching mtd5
[ 2.301405] ubi0: scanning is finished
[ 2.316370] ubi0: attached mtd5 (name “ubi”, size 112 MiB)
[ 2.321876] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.328742] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.335517] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.342467] ubi0: good PEBs: 896, bad PEBs: 0, corrupted PEBs: 0
[ 2.348463] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 2.355670] ubi0: max/mean erase counter: 20/7, WL threshold: 4096, image sequence number: 1761874204
[ 2.364876] ubi0: available PEBs: 0, total reserved PEBs: 896, PEBs reserved for bad PEB handling: 19
[ 2.374094] ubi0: background thread “ubi_bgt0d” started, PID 624
[ 2.380993] block ubiblock0_1: created from ubi0:1(rootfs)
[ 2.386493] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
[ 2.393585] clk: Disabling unused clocks
[ 2.406161] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 2.413541] Freeing unused kernel memory: 448K
[ 2.418046] Run /sbin/init as init process
[ 2.422131] with arguments:
[ 2.425085] /sbin/init
[ 2.427788] with environment:
[ 2.430916] HOME=/
[ 2.433263] TERM=linux
[ 2.697817] init: Console is alive
[ 2.701362] init: - watchdog -
[ 3.587375] random: crng init done
[ 3.775953] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 3.832413] usbcore: registered new interface driver usbfs
[ 3.837988] usbcore: registered new interface driver hub
[ 3.843338] usbcore: registered new device driver usb
[ 3.853987] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 3.866312] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 3.874683] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.879978] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 3.890407] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[ 3.899631] xhci-mtk 11200000.usb: irq 82, io mem 0x11200000
[ 3.905392] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.910629] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 3.918029] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 3.925539] hub 1-0:1.0: USB hub found
[ 3.929355] hub 1-0:1.0: 1 port detected
[ 3.933641] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.942159] hub 2-0:1.0: USB hub found
[ 3.945951] hub 2-0:1.0: 1 port detected
[ 3.957256] usbcore: registered new interface driver usb-storage
[ 3.964480] usbcore: registered new interface driver uas
[ 3.970127] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 3.987825] init: - preinit -
[ 4.458356] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 4.466824] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 4.510064] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 8.756715] mount_root: loading kmods from internal overlay
[ 8.780138] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 8.791340] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 8.999077] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[ 9.008073] block: unable to load configuration (fstab: Entry not found)
[ 9.014851] block: attempting to load /tmp/overlay/etc/config/fstab
[ 9.021244] block: unable to load configuration (fstab: Entry not found)
[ 9.027999] block: attempting to load /etc/config/fstab
[ 9.038061] block: unable to load configuration (fstab: Entry not found)
[ 9.044835] block: no usable configuration
[ 9.052087] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 9.057856] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 808
[ 9.113284] UBIFS (ubi0:2): recovery needed
[ 9.321126] UBIFS (ubi0:2): recovery completed
[ 9.325637] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
[ 9.333476] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 9.343383] UBIFS (ubi0:2): FS size: 80248832 bytes (76 MiB, 632 LEBs), max 643 LEBs, journal size 4063232 bytes (3 MiB, 32 LEBs)
[ 9.355022] UBIFS (ubi0:2): reserved for root: 3790350 bytes (3701 KiB)
[ 9.361626] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 3615F48C-6ABA-4E2A-847B-DDAE24A2C8F6, small LPT model
[ 9.375364] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 9.390879] block: extroot: not configured
[ 9.395109] UBIFS (ubi0:2): un-mount UBI device 0
[ 9.399839] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” stops
[ 9.410497] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 9.416247] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 811
[ 9.520305] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
[ 9.528148] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 9.538053] UBIFS (ubi0:2): FS size: 80248832 bytes (76 MiB, 632 LEBs), max 643 LEBs, journal size 4063232 bytes (3 MiB, 32 LEBs)
[ 9.549693] UBIFS (ubi0:2): reserved for root: 3790350 bytes (3701 KiB)
[ 9.556294] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 3615F48C-6ABA-4E2A-847B-DDAE24A2C8F6, small LPT model
[ 9.576274] mount_root: loading kmods from internal overlay
[ 9.598683] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 9.610084] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 9.714944] block: attempting to load /tmp/overlay/upper/etc/config/fstab
[ 9.728051] block: extroot: not configured
[ 9.733971] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 9.741253] block: extroot: not configured
[ 9.749334] mount_root: switching to ubifs overlay
[ 9.768234] overlayfs: null uuid detected in lower fs ‘/’, falling back to xino=off,index=off,nfs_export=off.
[ 9.785598] urandom-seed: Seeding with /etc/urandom.seed
[ 9.851917] procd: - early -
[ 9.854865] procd: - watchdog -
[ 10.422327] procd: - watchdog -
[ 10.428661] procd: - ubus -
[ 10.585932] procd: - init -
[ 11.398848] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.481069] NET: Registered PF_ALG protocol family
[ 11.504386] zram: Added device: zram0
[ 11.525810] urngd: v1.0.2 started.
[ 11.536545] OpenVPN data channel offload (ovpn-dco) 2.0.0 – (C) 2020- OpenVPN, Inc.
[ 11.546465] tun: Universal TUN/TAP device driver, 1.6
[ 11.557258] l2tp_core: L2TP core driver, V2.0
[ 11.562846] l2tp_netlink: L2TP netlink interface
[ 11.569099] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 11.577709] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 11.588476] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 11.608312] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 11.615976] gre: GRE over IPv4 demultiplexor driver
[ 11.628377] ip_gre: GRE over IPv4 tunneling driver
[ 11.811649] ppdev: user-space parallel port driver
[ 11.896559] lp: driver loaded but no devices found
[ 11.903088] GACT probability on
[ 11.907437] Mirror/redirect action on
[ 11.918468] u32 classifier
[ 11.921184] input device check on
[ 11.924835] Actions configured
[ 11.940824] ntfs3: Enabled Linux POSIX ACLs support
[ 11.948868] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 11.990498] Bridge firewalling registered
[ 11.998166] usbcore: registered new interface driver cdc_acm
[ 12.003830] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 12.013470] usbcore: registered new interface driver cdc_wdm
[ 12.021280] Loading modules backported from Linux version v6.12.96-0-g6d15a1029
[ 12.028654] Backport generated by backports.git d43b2b8
[ 12.159257] usbcore: registered new interface driver ums-alauda
[ 12.166602] usbcore: registered new interface driver ums-cypress
[ 12.174370] usbcore: registered new interface driver ums-datafab
[ 12.182063] usbcore: registered new interface driver ums-freecom
[ 12.189629] usbcore: registered new interface driver ums-isd200
[ 12.197117] usbcore: registered new interface driver ums-jumpshot
[ 12.204596] usbcore: registered new interface driver ums-karma
[ 12.212060] usbcore: registered new interface driver ums-sddr09
[ 12.219431] usbcore: registered new interface driver ums-sddr55
[ 12.226803] usbcore: registered new interface driver ums-usbat
[ 12.234368] usbcore: registered new interface driver usblp
[ 12.245879] usbcore: registered new interface driver usbserial_generic
[ 12.252587] usbserial: USB Serial support registered for generic
[ 12.272510] xt_time: kernel timezone is -0000
[ 12.278694] usbcore: registered new interface driver cdc_ether
[ 12.286570] usbcore: registered new interface driver cdc_ncm
[ 12.308476] usbcore: registered new interface driver huawei_cdc_ncm
[ 12.631562] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20240823161240a
[ 12.631562]
[ 12.942358] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20240823161304
[ 13.076165] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20240823161841
[ 13.175317] mt798x-wmac 18000000.wifi: registering led ‘mt76-phy0’
[ 13.258851] mt798x-wmac 18000000.wifi: registered 01E600
[ 13.265166] mt798x-wmac 18000000.wifi: registering led ‘mt76-phy1’
[ 13.374199] PPP generic driver version 2.4.2
[ 13.380925] PPP MPPE Compression module registered
[ 13.386898] NET: Registered PF_PPPOX protocol family
[ 13.393015] PPTP driver version 0.8.5
[ 13.398884] usbcore: registered new interface driver qmi_wwan
[ 13.406481] usbcore: registered new interface driver rndis_host
[ 13.416306] usbcore: registered new interface driver cdc_mbim
[ 13.424265] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 13.430398] usbcore: registered new interface driver option
[ 13.436073] usbserial: USB Serial support registered for GSM modem (1-port)
[ 13.446270] usbcore: registered new interface driver qcserial
[ 13.452131] usbserial: USB Serial support registered for Qualcomm USB modem
[ 13.459545] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 15.151020] zram0: detected capacity change from 0 to 495616
[ 15.180358] Adding 247804k swap on /dev/zram0. Priority:100 extents:1 across:247804k SSDsc
[ 15.676341] bridger[1925]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 22.029276] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 22.038063] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 22.038555] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 22.046225] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 22.050777] br-lan: port 1(lan1) entered blocking state
[ 22.050796] br-lan: port 1(lan1) entered disabled state
[ 22.050836] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[ 22.050846] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[ 22.054628] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[ 22.074097] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 22.074789] br-lan: port 2(lan2) entered blocking state
[ 22.074805] br-lan: port 2(lan2) entered disabled state
[ 22.074835] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[ 22.076473] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[ 22.096189] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 22.100057] br-lan: port 3(lan3) entered blocking state
[ 22.100077] br-lan: port 3(lan3) entered disabled state
[ 22.100119] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[ 22.102624] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[ 22.129832] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:00] driver [MediaTek MT7981 PHY] (irq=POLL)
[ 22.129854] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/gmii link mode
[ 22.130407] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 25.441843] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.441895] br-lan: port 3(lan3) entered blocking state
[ 25.441909] br-lan: port 3(lan3) entered forwarding state
[ 26.239871] br-lan: port 4(phy0-ap0) entered blocking state
[ 26.239891] br-lan: port 4(phy0-ap0) entered disabled state
[ 26.239933] mt798x-wmac 18000000.wifi phy0-ap0: entered allmulticast mode
[ 26.240137] mt798x-wmac 18000000.wifi phy0-ap0: entered promiscuous mode
[ 26.240247] br-lan: port 4(phy0-ap0) entered blocking state
[ 26.240258] br-lan: port 4(phy0-ap0) entered forwarding state
[ 26.275857] mt7530-mdio mdio-bus:1f lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[ 26.279082] br-lan: port 2(lan2) entered blocking state
[ 26.279107] br-lan: port 2(lan2) entered forwarding state
[ 26.450364] br-lan: port 4(phy0-ap0) entered disabled state
[ 26.611729] br-lan: port 5(phy1-ap0) entered blocking state
[ 26.611752] br-lan: port 5(phy1-ap0) entered disabled state
[ 26.611800] mt798x-wmac 18000000.wifi phy1-ap0: entered allmulticast mode
[ 26.611994] mt798x-wmac 18000000.wifi phy1-ap0: entered promiscuous mode
[ 26.612115] br-lan: port 5(phy1-ap0) entered blocking state
[ 26.612126] br-lan: port 5(phy1-ap0) entered forwarding state
[ 28.697842] br-lan: port 4(phy0-ap0) entered blocking state
[ 28.697868] br-lan: port 4(phy0-ap0) entered forwarding state
[ 4911.658041] br-lan: port 2(lan2) entered disabled state
[ 4911.658189] mt7530-mdio mdio-bus:1f lan2: Link is Down
[ 4913.878736] mt7530-mdio mdio-bus:1f lan2: Link is Up - 10Mbps/Full - flow control off
[ 4913.878765] br-lan: port 2(lan2) entered blocking state
[ 4913.878778] br-lan: port 2(lan2) entered forwarding state
[ 5871.885890] br-lan: port 2(lan2) entered disabled state
[ 5871.886039] mt7530-mdio mdio-bus:1f lan2: Link is Down
[ 5875.212375] mt7530-mdio mdio-bus:1f lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[ 5875.212411] br-lan: port 2(lan2) entered blocking state
[ 5875.212425] br-lan: port 2(lan2) entered forwarding state
