Какой либо пакет не ставлю пишет, что его нет в репозитории. Как исправить?
Обновите списки пакетов перед установкой какого-либо пакета, нажав “Обновить списки”.
Нажимал, все обновлялось без ошибок
Скопируйте полный текст вывода при обновлении списков и при установке.
Downloading http://github.com/routerich/packages.routerich/raw/23.05.5/routerich/Packages.gz
Updated list of available packages in /var/opkg-lists/routerich
Downloading http://github.com/routerich/packages.routerich/raw/23.05.5/routerich/Packages.sig
Signature check passed.
Downloading http://github.com/routerich/packages.routerich/raw/23.05.5/targets/mediatek/filogic/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading http://github.com/routerich/packages.routerich/raw/23.05.5/targets/mediatek/filogic/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/base/Packages.sig
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/luci/Packages.sig
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/routing/Packages.sig
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/telephony/Packages.sig
Установка проходит.
Upgrading luci-ssl on root from git-23.035.26083-7550ad6 to git-24.364.71483-75d2b84...
Downloading http://downloads.openwrt.org/releases/23.05.5/packages/aarch64_cortex-a53/luci/luci-ssl_git-24.364.71483-75d2b84_all.ipk
Configuring luci-ssl.
Только этот пакет не можете установить или любые?
У вас ipv6 подключение?
Любой, ipv4
А как его перепрошить? Есть ли тема с инструкциями?
Система - Восстановление/обновление - Установить новый образ прошивки
И выбрать файл прошивки.
Можете скачать последнюю версию: https://github.com/routerich/packages.routerich/raw/refs/heads/23.05.5/targets/mediatek/filogic/openwrt-mediatek-filogic-routerich_ax3000-squashfs-sysupgrade.bin
Перепрошил. проблемы остались, но паекты ставятся через Терминал
Пробовали в инкогнито режиме или в другом браузере?
Нет, какой браузер рекомендуется?
Любой отличный от текущего.
Спасибо! Открою еще тему про PPPoE
