в последний месяц стал пропадать wifi, а если быть точнее то выключаться и единственное что помогает это заход в настройки “сеть→беспроводна сеть” и включение каждой сети вручную. Обновил прошивку через ASU, но это не помогло
перед каждым таким выключением одинаковый лог
| Tue Nov 11 03:20:27 2025 | daemon | warn | odhcpd[2869]: No default route present, setting ra_lifetime to 0! |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: Set new config for phy phy1: |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: Remove interface ‘phy1’ |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy1-ap0: interface state ENABLED->DISABLED |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy1-ap0: AP-STA-DISCONNECTED 26:fd:a2:08:cc:86 |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy1-ap0: AP-DISABLED |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy1-ap0: CTRL-EVENT-TERMINATING |
| Tue Nov 11 03:24:57 2025 | daemon | err | hostapd: rmdir[ctrl_interface=/var/run/hostapd]: Permission denied |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: nl80211: deinit ifname=phy1-ap0 disabled_11b_rates=0 |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.421108] mt798x-wmac 18000000.wifi phy1-ap0: left allmulticast mode |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.427738] mt798x-wmac 18000000.wifi phy1-ap0: left promiscuous mode |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.434388] br-lan: port 5(phy1-ap0) entered disabled state |
| Tue Nov 11 03:24:57 2025 | daemon | notice | netifd: Network device ‘phy1-ap0’ link is down |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: Set new config for phy phy0: |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: Remove interface ‘phy0’ |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy0-ap0: interface state ENABLED->DISABLED |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy0-ap0: AP-DISABLED |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: phy0-ap0: CTRL-EVENT-TERMINATING |
| Tue Nov 11 03:24:57 2025 | daemon | notice | hostapd: nl80211: deinit ifname=phy0-ap0 disabled_11b_rates=0 |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.911095] mt798x-wmac 18000000.wifi phy0-ap0: left allmulticast mode |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.917751] mt798x-wmac 18000000.wifi phy0-ap0: left promiscuous mode |
| Tue Nov 11 03:24:57 2025 | kern | info | kernel: [224625.924485] br-lan: port 4(phy0-ap0) entered disabled state |
| Tue Nov 11 03:24:57 2025 | daemon | notice | netifd: Network device ‘phy0-ap0’ link is down |
| Tue Nov 11 03:24:57 2025 | daemon | notice | wpa_supplicant[2607]: Set new config for phy phy1 |
| Tue Nov 11 03:24:57 2025 | daemon | notice | wpa_supplicant[2607]: Set new config for phy phy0 |
| Tue Nov 11 03:24:57 2025 | daemon | notice | netifd: Wireless device ‘radio1’ is now down |
| Tue Nov 11 03:24:57 2025 | daemon | notice | netifd: Wireless device ‘radio0’ is now down |
